What is a normal thermostat size?
what temp range is normal for coffee makers, I have a capresso 454 with a defective 36tmh01 thermostat
retiree0105, the thermostat you inquired about is manufactured by Therm-O-Disc.
Series: 36T
Model: 36TMH01
Normally closed, opens at 221 degrees F (105 degrees C). More information can be found on here.
where is this thermostat? I see a lower range one on the heating element 154F/30C but I think that is warming only. My model 465 therm only has heat for brewing cycle as it has an insulated carafe and cannot take warming heat but I want to adapt to 464 specs and use a glass carafe. I think the only difference is the 465 has a heat shield above element (2nd plate with 2mm air gap) to block direct heating of base and possible disabling of 2hr post brew warm timer voltage to 30C thermostat.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 11
All Time: 2,391
1 Comment
thank you for a quick response
by retiree0105
