The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1505 Questions View all
2 iPhone 5c's with the same problem
Currently have two 5c's. They both have blank screens, both connect to itunes and both have had screen and battery replacements. Not sure where to look or what else to replace. Replacement screens and batteries were tested in working phones first. The 3 lcd connectors click in nicely on both devices too.
Has anyone experienced anything like it? or any suggestions on what to replace or look for.
Cheers
Add a comment
1 Answer
My first question is: Have you tried to use a verified, working display in either of the phones? Sounds to me like it could just be bad LCD screens for backlight problems. I used to see cases like this a lot with the iPhone 4s. The screen would be completely black and unresponsive, but the phone was fully working. This problem was always resolved by replacing the display. Try shining a bright light onto the screen to see if it is a bad backlight. If you can see faint images, either the physical backlight is out, or the backlight coil on the logic board is fried. The latter will require a logic board replacement or someone who knows micro-soldering and can replace the backlight coil.
Hope this Helps!
Comments:
Im sorry I never got back to this. Sold the devices on for parts, will keep this in mind for future encounters. Cheers
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 91
