2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
After I add a dual HDD, can I merge with existing HDD?
I have a 64 GB SSD in my 2008 MBP's hard drive bay right now. I want to add a second SSD using the optical drive replacement piece. Is there a way for both drives to act as one in OS X? Or would the second SSD have to be a separate drive?
Score -1
Add a comment
1 Answer
Chosen Solution
First lets make sure we understand things here:
  • The first way is setting up a RAID set. Here's a write-up that explains them Standard RAID levels.
  • The second way is setting up a Apple Fusion drive which is similar to RAID 0 but smarter when you have a HD and a SSD.
RAID'ing is a very good way to improve access speed and/or reliability, but it comes with a cost depending on which RAID level to go with. RAID 0 is great for speed but it can put your data a risk if one drive fails. RAID 1 offers a fail safe image if one drive fails and it still can offer some speed improvement but not as much as RAID 0.
Frankly, I think its smarter to go with an external drive which is setup with RAID 5 if you really want both the speed and the protection.
Apples Fusion drive won't work here as you have two high speed SSD's so there is no gain. If you had a HD in one drive bay then I would go with it.
Score 1
Add a comment
Add your answer
Zach Lucas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 92
