Mac Pro Airport (WiFi) inquiry
I was wondering if I could put my MacBook (older white plastic model) into my Mac Pro desktop which does not have airport in it.
Don't see any way that you could do that. ;-{
Can you give us the last 4 numbers of your serial number so we can identify which Desktop system you have. Depending on what you have it maybe a simple fix.
Open your system up and looking just under the second fan unit on the main logic board you should see a connector and a few cables held to the side. Here's a good image on what you should see (minus the AirPort card): AirPort & BT boards.
If its enmity you can put in an Airport Extreme Card P/N: 661-4060
Otherwise, you'll need to use an external USB WiFi adapter.
Full serial: G871022XUQ2
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 146
1 Comment
Mac Pro - Quad Core (Original)
by Dan
