Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
iPhone doesn't work after repairing front panel and rear panel
Hi,
i got the same problem but it is was my own iphone before (definately no fluid damage or something like that) and it worked before I opened it. After having changed the rear panel and the front panel because both was broken ot worked once. I then opened it again because the camera wasn't set properly and after that it didn't work anymore. I was very carefull not to damage anything inside.
the name looks a little bit german to me. hard to tell whats wrong with it - i can't see dead devices in my crystal ball (kiddin) - it could be anything. if you were carefull and didn't break anything - it could be anything. but please start a new question for that - it youl be easier to handle
markus weiher, 20 minutes ago
Ok, openend a new question. The name itself is russian but I'm german, that's correct.
Update: I plugged it into my computer and after about one minute the screen shows vertical black stripes at first very weak but becoming stronger after a while. The battery was only at 10 % when I turned it on the last time. Was it the battery's death?
2 Comments
i know that it's a russian name, but the spelling would most likely be different. aber das macht nix, manche namen fallen einfach auf ;-)
by
Ja, "Weiher" ist ja auch nicht grade unauffällig in 'nem englischsprachigen Forum...
by
Add a comment
1 Answer
Chosen Solution
i'll try to explain it.
the battery could have been shorted during the disassembling/reassembling process.
that would mean that the battery can "play" dead.
the vertical black stripes are not that good - i think that the lcd is faulty or the connection is pretty bad
there are not that many options - check the connectors, make a hard reset or restore it with itunes
i would check the connectors and maybe reset the phone.
7 Comments:
The connectors are looking fine and sitting propperly (it clicks hearable when connecting or disconnecting). But I will have a closer look again with a magnifying glass.
The lcd was fine until now and I never had any problems with it. At least with a faulty lcd the sound should be hearable when charging it, shouldn't it?
The hard reset dooesn't work and itunes won't recognize it.
by
connector 4 is ok? (thats the one for the dock connector, speakers and so on)
by
Yes, also connector 4 looks pretty good.
by
i would charge it overnight and try to start it "tomorrow" - checking everything with a good magnifier is one of the last options - everything else goes most likely to far - you can always send an email: markus.weiher@gmail.com - it's bedtime, i'll be back in around 4hrs
by
Thanks, I will try to charge over night. Then sleep well.
by
Show 2 more comments
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 314
