Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
954 Questions View all
Exposed to rain, cleaned interior, iTunes won't restore
I got caught in a rain/hail storm and my iPod classic got wet. I turned it off immediately and let it dry for a few hours. I plugged it into my computer and it didn't respond, so I put it in a bag of rice for a week. Still no response. I left it plugged into my computer for 24 hours, tried it in a wall plug and in the car, but no response.
I opened the case and cleaned all surfaces with isopropyl alcohol. There was dirt/grit inside, but I didn't see any corrosion (I don't know that I'd be able to recognize it).
I let it dry, put it back together and plugged it into my computer. I hold down the centre button and the Menu button and, after 10 seconds, iTunes says:
Waiting for iPod...
iTunes needs to prepare your iPod for recovery. Please leave your iPod connected.
Preparing iPod for recovery...
But then nothing happens. Other posts indicate that my next step should be to replace the battery. Just want to check that, with my symptoms, this is what I should do. There were visible wrinkles in the foil surrounding the battery when I opened the iPod, but I assumed these were on the protective foil, and not on the battery itself. I'm not sure. The wrinkles were easily flattened with my fingernail. (My battery was silver, not blue like the one pictured in the teardown iPod Classic Teardown). Again, not sure if this was the actual battery or just a foil overtop of it, but I was afraid to tamper with the lithium.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Junior Recycler, just like any other device. Once it has been submerged it needs to be cleaned, before charging or syncing or otherwise turned on. Always replace the battery after exposure. These batteries react highly with any kind of moisture. So replace it, remove your logic board and clean everything. Use a high grade 90%+ isopropyl alcohol and a soft brush. Do not forget the dock connector. Then let it dry replace the battery and re-evaluate. It is possible that you are also running into HDD problems. You also want to try the diagnostic menu and see what happens.
Score 2
Comments:
Thanks for your help. I successfully replaced the battery, but now I get the dreaded "red x". Tried to run SMARTDATA in diagnostics mode but it said [Can't Open Device] Error! Diag Halt. Obviously there's been more damage... What do you normally replace next? Hard drive or logic board? What are the chances that, after I replace one, I'll just have to replace the other? I'm having fun tinkering, but not sure about the cost of all the replacement parts.
by
Sounds like a damaged hard drive
by
Add a comment
Add your answer
Junior Recycler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 222
