The Philips model GC8220/02 is a pressurized steam generator that uses a 1.4-liter detachable water tank for ironing and steaming fabrics.
17 Questions View all
Why my steam iron can't get steam come out
The steam iron, I get the problem is steam don't came out...when I press the pressure button on the handle ,steam don't came out n the water still get boilling no steam out. How can I fix it?
Score 4
Add a comment
Chosen Solution
Hello,
I would try using a 50/50 mixture of distilled water and vinegar. I use this mixture to clean my coffee pot and steam mop. 90% of the time it works everytime!
Score 3
Add a comment
Hello!
I just find some good web page. This problem is related to electronic, pump power supply.
https://lieven.kks36.be/2016/06/11/phili...
I hope it will help You.
Best regards!
Marin
2 Comments:
How can I solve my steam generator problems, it do trip off if you pressed pressure bottom on the handle and steam doesn't come even after I cleaned it with 50/50 with white vinegar. Bello
by
Brilliant thank you. It's working now. 😁👏
by
Add a comment
Try opening cap where the water is topped up. If it starts to steam then, on my Philips Azur, there are two tiny pinholes in the cap which were blocked. A poke with a pin was enough to sort the problem. They allow air to enter as it steams, otherwise a vacum would occur and stop the water flowing.
Add a comment
Add your answer
phongtu008 will be eternally grateful.
Past 24 Hours: 21
Past 7 Days: 90
Past 30 Days: 440
All Time: 68,164
