Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Why isn't my iPod turning on?
My Ipod touch 4th gen 8gb isn't turning on... it makes a charging sound when you connect it to a usb and it also can do voice control... can someone help me?
Add a comment
This answer was originally to another question.
start to lightly tap it, maybe it will snap loose.
2 Comments:
yeah it didn't work but thx anyways :)
by
the only other thing to fix it, is to take it apart and replace it. the only thing to get it working now without fixing it is to turn on touch assist in your settings to give you a on screen button to use as a power button. settings - general - accessibility - assistivetouch.
by
Add a comment
its your power button and volume ribbon cable. replacing the cable will fix your issue but it requires steady hands and soldering.
1 Comment:
really??/ thx i could do it... i am young and have steady songs... but it could play songs with voice control.... so..... it actually works???
by
Add a comment
Try a hard reset by holding the home and power button for 10 seconds. If that doesn't work it is possible that the LCD is unplugged or the backlight is burned out. Was the ipod dropped or water damaged?
1 Comment:
uhhhhh i did hard reset like 10 times, and yes i have dropped it in water but then i dried it with a hair dryer and i but it in a bag of dry rice for 3 days. And apparently my power button and volume ribbon cable is cut...
http://cdn.macrumors.com/article/2010/09...
does replacing the lcd screen and the cable fix it??
and please reply asap
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
