iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Replaced battery and HDD, iPod won't turn on
The HDD on my 120 GB iPod Classic (6th Gen) recently went bad, so I bought a Tarkan iFlash (ZIF to CF to SD) adapter and a 128 GB SD card off his list of recommended cards. At the suggestion of many, I also bought a replacement battery from ipodbatterydepot.com. I've installed both, but things are not working as expected.
When I turn HOLD off, nothing happens. When I connect the iPod to my computer (Windows 7) with HOLD on, nothing happens. When I switch HOLD off, the screen blinks on and off (on for a second, off for a second, repeat) and shows the Apple logo when on. Holding Center+Menu slows the blink rate down to about 3 seconds, but does nothing else. Holding Center+Play does nothing.
I left it connected for 24 hours hoping that the battery just needed to charge, but it still behaves like it did yesterday.
I tried re-seating all the ribbon cables and everything seems fine. I tried reformatting the SD card to FAT32 as others have suggested, but the only formatting options on my computer are exFAT and NTFS, so I left it as exFAT.
Score 1
Add a comment
1 Answer
It is obvious that NTFS beats FAT in many aspects.
NTFS main advantages over FAT:
  • Handle large files (over 4GB).
  • Get better stability, higher security and lesser defragmentation time.
It seems like that you did not have a clear idea on the difference between the two file system
1 Comment:
@v3nuo
You are coming very close to get some repercussion from your habitual spamming. You are always linking to the same site which makes your answers spam. Be advised!
by
Add a comment
Add your answer
Scott Perron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 192
