Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
86 Questions View all
Question Closed
Took Carburetor apart...now wont prime.
My Echo SRM 261-t string trimmer was four stroking and would not go into high rpms as a 2 stroke should so I took the carb off to make sure everything was clean. It all looked good (I cleaned everything anyways) so I put it back together and now the primer bulb does not work. I took it apart again to double check I got everything back right and i can not find an issue. It is as if the air can't escape from the bulb so it can suck up the gas. It feels like you are just pressing on an air bubble but the air cant go anywhere. what did I do? Thanks, DJ
Add a comment
1 Answer
Chosen Solution
I don't know what happened but after posting this I went back to the shop and it was working normally. Back in business for my face off with a scythe tomorrow!!!!
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 654
