Engine siezed. Parked then wouldn't start
Engine won't start
Update
Took out starter Turned engine by hand. It won't turn.
Engine won't start
If you absolutely can not turn your engine over (remove the accessory belt and use a breaker bar with the appropriate socket on the crankshaft pulley) than you most likely have some severe engine damage. Not much you can do on a seized engine other than to replace it.
There is starter coil between battery and starter motor, try replacing this.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 201
