20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Questions View all
Question Closed
Won't boot up if the usb and firewire is connected
I have an issue with an apple 30" cinema display not booting up when the usb adapter and the fire wire cable are attached to the mac pro. If I just connect the VGA to the computer then it boots up and runs fine, however this means that I cannot use the Firewire or USB ports on the monitor. Not a deal breaker, but an inconvenience. Any idea how to fix this?
1 Comment
Can you tell us the model info for your display.
by
Add a comment
1 Answer
Most Helpful Answer
Are you using the same power strip to plug both the system and the display in? Hopefully, this is a surge suppressor.
Try disconnecting the devices from the displays ports and just plug in the USB cable alone, what happens? Then try the FireWire connection alone, what happened then?
Score 1
2 Comments:
The only way that it turns on is when only the DVI adapter is connected to the Mac Pro. If the fire wire is connected, it shuts off. If the USB is connected, it shuts off. I have two identical 30" HD cinema displays, and only one behaves this way. I heard somewhere that it's an issue with the power inverter in the monitor, but I'm unsure if that's the case.
by
Can you give us the model number of the display
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 180
