Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
iPhone 5c: Replaced lightning port and battery but still won't charge?!
My daughter did a number on her iPhone 5c and I replaced the lightning port assembly, the loudspeaker assembly and the battery. Now the battery won't charge. When I plug the cable in I get the tone and the charging icon but the battery level never goes up.
1 Comment:
Did you try to see if it makes a difference if you re-install the old battery?
by
Add a comment
This might be a dumb question, but have you tried a different cable?
1 Comment:
I tried 3 different cables, two different AC adapters and plugging it into the wall and the computer (3 different USB ports). No dice.
by
Add a comment
What exactly happened to the iPhone while in your daughter's possession? You may possibly be experiencing a failure in the logic board "power management ic", assuming your replacement battery-cable-connector wasn't somehow defective. It is generally an uncommon occurrence (and an expensive fix, unfortunately), but some experts think cheap, "fake" Apple chargers/cables are to blame for the bulk of these failures. Please check out this article to see if it sounds like your problem: https://www.mendmyi.com/blog/2014/06/has...
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 244
