The Lenovo IdeaTab A1000L is a 7-inch tablet that was released in 2013.
9 Questions View all
Why won't my Lenovo tablet turn on?
Hello! I bought a Lenovo IdeaTab a little over a year ago, and it has been working fine throughout that time, save for a few times when it froze and I had to reset it. But, a couple of weeks ago, the screen froze and I could not turn it off, so I held the power button down for a little while and waited for it to shut down. When it finally did power off, I waited about five minutes and tried turning it back on, but it would not power on. It didn't do anything, so I thought No big deal, this has happened a couple of times before. I held the reset button, which had worked all of the other times, but it still would not turn on. Since then I have tried everything; charging it and then holding the power button for twenty seconds, and then unplugging it and holding the power button, I also tried that with the reset button, but to no avail. I've tried holding the power and reset button at the same time, plugging it into my computer, using a different charger, taking the battery out and putting it back in, basically everything I found online. I don't know what else to do, please help.
Score 4
1 Comment
i need help my tablet not open.
by
Add a comment
1 Answer
Chosen Solution
Hi,
You may have to perform a hard reset to get you tablet to start again.
Be aware that a hard reset will erase all your downloaded apps and user data and restores your Tab to factory default
Here is a link that shows you how to do it. Please ensure if you can that the battery is charged or has some charge before you perform a hard reset. (see comment a bottom of page in link re charger)
Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset)
Be patient, it takes a few minutes to reset.
Score 2
Add a comment
Add your answer
Haley Nelson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 19
All Time: 1,634
