Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Questions View all
Xbox One no wifi connection wireless or wired -Please Help!
While playing on my machine I lost internet connection. I did the usual checks and there was no problem with any other equipment in the house connecting. I have rebooted and after that reset the system and nothing has worked. As I have reset the system I am now locked out of the machine altogether as the machine needs to connect to the internet during initial set up. I now get a message saying there is a hardware failure.
I have repaired DS’s PS3’s etc. and so quite willing to open her up but looking for some guidance.
Is this likely to be a WIFI board failure? From the teardown here I see the WIFI board is connected to the RF board, is it that that may have failed? If it could be either is there a test I can do? Finally I have check out eBay and none of these parts are available there so any ideas where they can be purchased? Any and all help gratefully received.
Many thanks Dan
Score 4
1 Comment
Hello I have a concern on my Xbox one about the wifi...I can not connect to the internet only connected via router, none of the list of wifis pop up. And when I click the tab to check my connection it says i'm all good and connected to the internet but i'm not that's the issue. i have tried hard resetting, factory resetting and nothing works still. Is there any way this is the issue with the wifi card inside the console? or should i follow the HDMI tip? i'm not sure what to do on this so if someone could help me that would be very much appreciated :(
by
Add a comment
Most Helpful Answer
Well, had this network problem where my xbox though i was plugged and there was no signal no internet ... i guess the wifi automatically turns off when it thinks its wired .... Microsoft will tell you to send it so they can take about 150$ away from you ... I fixed the problem on my own... curiously, it interprets certain hdmi cable as ethernet ... i don’t know why, And it’s still a theory .... but my wifi comes back with no problem every times i start my xbox without hdmi plugged in .... then I plug it in, and voila ... everything is working great again!
Score 3
4 Comments:
You GENIUS!!! - I’ve had this problem repeatedly for months!! This week the console finally gave up and i’ve been locked out of all games & apps over the console sensing a ‘Wired connection’ thus not letting me access WiFi! I followed your advice and yanked HDMI out of console (the one connecting to TV) and held down illuminated console power button to force reset as you can’t see the TV screen with HDMI unplugged! Then gave it a minute and pressed console power button to power up still with HDMI out (blind) gave it a minute till I was sure it would be on home screen then replugged my TV’s HDMI cable back in console! As you said my friend... Voila! EVERYTHING works again as normal! Now playing games again! You LEGEND!! Best advice EVER & the quickest fix! Hope it works just as well for others. Cheers!
by
Fantastic!! Not even the ms website comes with such a simple effective solution! You should apply for a job at ms!
by
i’ve had this problem for months now for as long as i can remember and i finally tried this & it really works thank you so much bless your soul
by
You’re the &&^&^$^ GOAT bro.
by
Add a comment
I know this post is kind of old but all you have to do is unplug it from the wall for about 30 secs..plug it back up and it'll be working
Score 2
Add a comment
Hi I am having the exact same problem and would love to know a fix?
1 Comment:
I'm guessing no one knows an answer to this one mate as no reply to my first question in 3 days.
Guess I'm just going to investigate blind.
Wish me luck :)
by
Add a comment
Ok I have tried and a different test and working WiFi Board which made no difference (wasted £30.00). I have tried a working RF Board and still no solution.
I am next going to reflow the Realtek RTL 8151GNM Ethernet Controller chip - wish me luck :/
3 Comments:
I reflowed the chip and the unit now works Hurray! :)
by
Can you tell us more about what you did?
by
Hi Dan, can I just ask a question.did you use thermal paste for the reflow? Or just direct Heat? I have the same problem. Your help would be really appreciated, thanks
by
Add a comment
What's reflow?
I opened my system and my wifi card was bend and a tiny piece from the corner snapped off... Would that affect the wired Ethernet connection as well since I can't get internet either thru wifi or Ethernet
5 Comments:
Did you manage to fix this fault mate? have same and its got me totally puzzled?
by
Hi guys I had to reflow the Realtek RTL 8151GNM Ethernet Controller chip.
You can search reflow and the chip on Google. If you are not comfortable reflowing you may need to take it to a repairs workshop. Good luck.
by
HI Dan
thanks for the reply.Did you use a heat gun or the oven method? and for how long ?i tried a heat gun on rtl chip but only for a minute.when connected to a wired dynamode adapter can see it connected to virgin superhub but still says on xbox screen "there's a hardware problem" also noted cant sync controller so wonder if RF board fault is affecting it as well.
cheers
Tom
by
Hi Tom, I used a hot air work station I have. Cannot remember how long I applied the heat but would guess a couple of mins at about 300c. The only problem I had was not connecting to wifi so not really experienced your other problems.
Sorry can't be of more help - Dan
by
Cheers Dan ,
Thanks for the info, will give it a blast see how it comes along .
by
Add a comment
Dan
im so glad that you posted this due to Im currently having the same issue right now as we speak and wanted more information as far as can this be done by anyone or will i be better off going to a computer repair store or geek squad?
Rell
Add a comment
Well I had this problem but I fixed it. What I did was I ordered from ebay the wireless/bluetooth card and i changed it by my self and it worked. Check on youtube how to open your xbox and stuff.
I have couple notes here
1. Opening your xbox will ruin your warranty just incase you didn't know.
2. You'll need a security screw driver. But maybe you can help your self with a flat screwdriver. I read that some people did it.
3. I ordered the wifi/bluetooth CARD not the antenna.
Add a comment
I think the hardware problem is just a pile of poop. I went to game shop 4 times and said they can't do anything' I have insurance' then I ask them to check and it works fine so I tested it at my house and it's crap. I plugged in a ithernet cable and tried it it was fine. Then the controller disconnected and then I thought grate so what I done is recorded everything and going to show them tomorrow..... ABSOLUTELY TERRIBLE
Add a comment
None of you’re solutions worked.
Add a comment
None of your solutions worked
Add a comment
Make sure you’re using the HDMI cable that came with the xbox one s. Some hdmi cables confuse the wifi network card into thinking that a hard lined ethernet connection is active, when it clearly is not.
1 Comment:
if you could email me? or something to help me jcaruso0318@gmail.com :)
by
Add a comment
You need a new internet board
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 32
All Time: 29,588
