Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Question Closed
Access ok but won't click
Question for a champion Mac:
I have a Macbook Pro mid 2009 3.06 GHz Intel Core 2 Duo.
I do not understand why I could scroll the mouse or trackpad but I could not click on anything. Even the deliberately hidden dock did not appear. I quickly realized that this was a problem "hardware". Having tried everything, my girlfriend told me to try to remove a screw from both covered below. What I did and MAGIC. I noticed that in the last two-tightening screw corner (below the screen) I still lost the ability to click.
Q. - Where is the problem?
1 Comment:
Question pour un champion Mac:
J'ai un Macbook pro mid 2009. 3,06 GHz Intel Core 2 Duo.
Je ne comprenais pas pourquoi j'arrivais à faire défiler la souris ou le trackpad mais je ne pouvais cliquer sur rien. Même le dock caché volontairement ne voulait pas apparaître. J'ai vite compris qu'il s'agissait d'un problème «hardware». Après avoir tout essayé, ma blonde m'a dit d'essayer d'enlever une vis à la fois du couvert de dessous. Ce que j'ai fait et MAGIE. J'ai remarqué qu'en serrant trop les deux dernières vis des coins (dessous l'écran) je perdais encore la possibilité de cliquer. QUESTION - Où est le problème?
by
Add a comment
Sounds like you need a new trackpad, there is a replacement guide on ifixit. They have a tendency to stop clicking but continue to register movement.
1 Comment:
Impossible because the mouse is doing the same. When I loose the screws in the top back both works perfectly. I would like to know want can it touch when it's too tight...
by
Add a comment
your battery has most likely swollen up and is pushing on the bottom of the track pad. remove the battery and see if it has expanded. if so replace it and recycle the old one at a store that accepts electronics for recycling like best buy or staples. if the battery looks fine then you need a new track pad.
Add a comment
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 115
