Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
Camera doesn't work. It's not the camera.
Hello together,
I bought an used iPhone 4. After some weeks the phone was dead, because the batterie was broken. So I changed it.
After this replacement, the phoned work good. One evening, I tried to make some photos with the back camera. The first pictures were no problem but then the screen was black. I tapped around on the screen but nothing. I restarted the phone, nothing, so I recovered the phone and nothing again.
As I said, the screen is black. But it's not black like the lense is blocking. If I knock on the phone, I see much purple stripes on the screen but not the motif. The light is also not working, only somtimes. I can change the HDR mode and can use the front camera.
The last thing I tried was, to change the camera&light modul. But the same failures.
I would say the connector port on the logicboard is faulty but it looks good. All pins are on the right place und there is no dust.
Any ideas, what I can do?
Add a comment
1 Answer
A little push and update.
Yesterday, I cleaned the camera connector and the golden hole right from the camera with 99% Isopropanol and let it dry over night. But the problem is not solved. :( Here is a picture from the screen in the camera mode. I have no idea what's wrong. I forgott to write, that the flashlight is also not working.
Screenshot
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
