Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1701 Questions View all
Question Closed
Water not rising to icemaker?
I'm connecting a previously functioning icemaker that was without a water line for the last few years, but the fridge was still in use. The external line goes into the base of the fridge. A second line comes out of the base and goes up to the icemaker. I can see the water has risen about 2/3 of the way up the 2nd line to the icemaker, but has stopped. The icemaker is set "on" via arm position in the freezer. The external line is on. Not sure what is next. More info as I uncover it.
Add a comment
1 Answer
Chosen Solution
Solution:
The water line just needed time to come up to the ice maker. After a few hours and a shake, it eventually went up and filled the ice tray.
I also found a guide that may assist with this icemaker:
http://www.ehow.com/how_12021705_trouble...
Edits for the guide:
Re: Step One, the sensor arm going "up to the right" is clearly labeled as the "OFF" position on mine.
Re: Step Two, the *LARGE* nylon gear
Bonus: The adjustment screw behind the plastic face plate on the unit is apparently for water level, and is very fragile.
Score 1
Add a comment
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 7
All Time: 133
