Repair and service information regarding the Lenovo S920, an Android smartphone that was announced in March 2013.
5 Questions View all
Why won't my phone power on?
hai..i have lenovo s920..but the problem is cannot turn on but red light lighting when i connect to pc.is there have solution that can guide me.or my phone cannot been repair anymore?
Score 39
3 Comments
My lenovo s90 is not working and it is not working and it is not oning.
by
i acquired a new lenovo k5ic78, i have tried to charge but it cant get switched on. what could the problem be?
by
need help please
by
Add a comment
Most Helpful Answer
My lenovo mobile not able to on
Score 2
Add a comment
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. Do you know how to fix it?
Update (08/29/2015)
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. If you're gonna ask if it's low bat, it's not. Do you know how to fix it? Please help me with this problem.
Score 1
5 Comments:
First you have to check whether any short circuit on PCB, No shorting then you check the ON?OFF switch. any damage resolder or replace the ON/OFF button.
by
If there is no damage in ON/OFF button flash the device . again it won't power ON then reheat the cpu and check, reball the cpuand check, Replace the cpu and check. no solution now change the PBA.
by
U do all these things after check the battery output. and have to check oscillator outputs..
by
I have the same problem .. but I did not drop my phone ... I just woke up in the morning trying to open my phone and the same problem happened ....
by
i have a problem of s90 lenovo, it wont power on, but it vibrates and there's a red light besides the camera hole(front).will you help me how to fix?
by
Add a comment
i had the same problems .. but i manage to solved it.
download the stock rom and try flash it using SP Flash Tools .
your device will surely revive from dead ..
:D
Score 1
Add a comment
so many answer, number 1 is , no battery
Add a comment
What do I do ? I bought a phone from Lenovo then when it came I charged it for about 15 h then when i went to turn it on it didn't do anything so I charged it for 6 h and it still didn't do anything . It's been almost 2 days and it still doesn't turn on . I tried pressing volume + and power still didn't work I tried volume- and power still didn't do anything, I tried +and - and volume doesn't work . PLS HELP ME!!!!!
Add a comment
have same problem. need help
Add a comment
step 1 gather some strength
step 2 hold your phone really tight
step 3 smash it to the ground and say &&^& this.
Add a comment
what you need is you want to kill kids ( In Game ) until you’ve gathered sum POWER and then what you need is Flash your phone with stock ROM.
ENJOY :)
Add a comment
Add your answer
ejam219018 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 12,985
