Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Questions View all
Ipad 4 doesn't charge
Hello, I installed a new battery and a new lightning port. My iPad turn on, but the battery doesn't charge, when I plugged it to the power outlet, the iPad only indicates "battery charged" when It had only 65% of charge. Only It charges, when my iPad is turn off, but when It turn on, it didn't charge. Now, my iPad doesn't turn on. I changed the battery two times. Also, I re-installed the old lightning port.
Score -1
Add a comment
1 Answer
Chosen Solution
It is very likely that you have damaged the U2 charging logic ic chip, probably happened because you created a short on the main board while trying to replace the battery. It is repairable but it requires a board level repair.
Score 1
1 Comment:
do you happen to have a picture of the chip that needs to be replaced
by
Add a comment
Add your answer
Michael Beltran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 483
