Repair guides for Windows cell phones manufactured by Nokia.
600 Questions View all
My Nokia Lumia 735 dropped in water! What to do?
My phone has been dropped into a toilet. I have dried it out with a paper towel, but the touchscreen just won't work + the screen just shows the image in yellow with... like lines... you know. And the flashlight always works... Please help.
Score 1
Comments:
+ It doesn't always turn on. Help please.
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Vlad, just like any other device that has a water immersion, it needs to be cleaned properly. Disassemble your Nokia, then clean every part with a high grade (90%+) isopropyl alcohol. Do not forget to clean all the cable connectors. While you clean, do a visual inspection and check for any missing, broken components. After you cleaned the Nokia, replace the battery. Cleaning the phone is a must to prevent corrosion damage. After you clean it and replace the battery, re-evaluate. Water damage is the toughest to diagnose since it is hard to determine which part has failed.
Score 1
Comments:
Thank you for your answer. I have actually found out that it has got dirty inside because of the water it has absorbed. It was just all white, I was shocked. Once again, thank you.
by
Add a comment
Add your answer
Vlad will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,717
