The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Motherboard issues won't restore
So I have an iPad 2 and an iPad mini which seem to have similar problems. Both are recognized by iTunes as being in recovery mode. The problem is that when iTunes tries to upload the latest firmware to the iPad iTunes just hangs on waiting for iPad. Both iPads boot up to the Apple logo and show an empty status bar underneath the logo and that's it.
I've put both logic boards under a microscope and there are no obvious signs of damage. I was hoping that someone on here may have solved a similar problem or at least had some trouble shooting directions. I've tried multiple PCs and doc cables but no luck.
Score 4
1 Comment
So do I...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch anywhere...so I am inclined to think that a hardware failure is the root cause...instead I seem to suspect that when the latest version of IOS came out...might be related...not sure if my iPad 2 was configured to automatically upgrade it's firmware or not or if this was even an option...otherwise, I am stuck with a boat anchor now...thanks
by
Add a comment
Most Helpful Answer
Hello Brian, you can try a different connector port from another ipad that works, but I'm not sure if that will be the problem, it's hard to know!
Good luck dude, keep us posted if you want
Score 1
1 Comment:
Shouldn't even answered the question, if you cannot solve the problem keep the question against you chest and wait until someone come up with a solution.
by
Add a comment
So do I Brian...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch on it anywhere...so I am rather inclined to think that a hardware failure is NOT the root cause...instead I seem to suspect that when the latest version of IOS came out...this might be related...also not sure if my iPad 2 was configured to automatically upgrade it's firmware upon a new release and/or whether this was even an option...otherwise, I am stuck with a boat anchor now...the iPad store techs don't have any idea either...thanks
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 14
All Time: 1,048
