What could be the problem?
I just replaced the screen and digitizer on my phone and touch doesn't work
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 169
