Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Questions View all
Question Closed
brake lights don't work when I press on the brake light pedal
I have a 1991 Chevrolet Cheyenne v6 4.7 liter 5 speed extended cab pick up and my running lights work in the tail light assembly, but the brake lights don't work when I press on the brake light pedal. I replaced the brake light indicator underneath the dashboard that snaps onto the physical brake arm itself underneath dash, I had a shady tree mechanic rewire the wiring for my brake lights underneath the bed of the pick up in the back by the lights themselves. It worked good for a while but now neither brake light lights up ,so I think maybe a wire may have came loose in that back area. could you tell me what color wire that connects to the brakes underneath bed of truck. please e-mail me at lemleyjrjohn@yahoo.com thank you god bless
Add a comment
1 Answer
I do believe this is correct coloring for the wires. More than likely it would be a wire or a fuse issue if you have replaced the switch on the pedal already.
Green = right side stop light/turn signal
Yellow = left side stop light/turn signal
Brown = tail lights & license plate lights
Light green = backup lights
Black = ground
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 387
