The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Questions View all
Question Closed
no power going to console, won't turn on
Last night my console died. I was playing a game and it suddenly turned off and won't turn back on. There is no light on the power brick at all, tried different sockets, checked all connections, USB ports nada.... Any advice please? Should I buy another brick? Thanks
Add a comment
deakinwoods. unless you want to take the power supply apart and check it. There is a fuse and a few other items in the power supply that can be replaced if those are the ones that have failed. If you do not have the tools or the skills to fix it, the only option you have then is to replace it. It all depends on you.
Add a comment
Hi borrow one of your friends power supply to rule out if the power supply is bad are it's the console itself..
Add a comment
It will be the power supply that is faulty, try another one
Add a comment
open power suply box and look red wire . If is not connected to power suply then you must connectet on in . Red wire is conectror bettwen xbox and power suply for
electricity
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 762
