The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
429 Questions View all
Question Closed
My xbox turn on, but no have video. What problem is?
I buy a xbox from 250 mxn (I am mexican) with red ring and i repair it, but my brother dropped my xbox and not send video, after reviewing change you a capacitor and now gave the ring of death, reboot it and again did not return to send video, which believe that is my problem.
The motherboard is the xenon.
Sorry for my bad english
Español
Compre un xbox por 250 pesos mexicanos (soy mexicano) con el aro de la muerte y lo repare, pero mi hermano dejo caer mi xbox y ahora no manda video, despues de revisarlo le cambie un condensador y dio el aro de la muerte, lo reinicie y volvio a no mandar video, cual sera mi problema?.
Mi placa madre es la xenon
NOTES/NOTAS
One day was in my shop trying to fix it and the warm long (then leave you the 2 lights gave him warmer heat with the air pistol to 450 and some 15 minutes), then you turn it off and let a day enfriandose, the next day when the putdown, quickly gave the 2 red lights and was not hot, it will be?
Un dia estaba en mi taller intentando repararlo y lo calente mucho (despues que le salieran las 2 luces le di mas calor con la pistola de aire caliente a 450 y unos 15 minutos), luego lo apague y lo deje un dia enfriandose, al siguiente dia cuando lo prendi, rapido dio las 2 luces rojas y no estaba caliente, que sera?
Add a comment
1 Answer
Most Helpful Answer
I would try and re-flow the console again, I have experienced display problems being fixed by also re-flowing the HANA chip as well as the CPU and GPU. IMAGE
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 76
