The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Questions View all
Why won't my controllers connect?
I have an Xbox 360 S, and the controllers will not sync with it. I've tried everything I could find online, and even replaced the rf modulator. I tried plugging them in with a wireless controller with a charging usb cord, and that didn't work either. Any help would be greatly appreciated.
Score -1
Add a comment
1 Answer
Do you have any wireless routers, microwaves or metallic objects positioned anywhere near your console? These can disrupt the signal or wireless controllers. As far as plugging it in to play that only works if you use the play and charge kit. Which asks you to connect the battery pack to the USB cable and that to the console. If after all of this still nothing is working your USB ports may be damaged, or the console itself may be damaged. If you can also try using friends controllers to test whether or not it is the controller that is malfunctioning.
Add a comment
Add your answer
Pat will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,200
