The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
Touch screen doesn't work,No water damage, No connection problems.
Hi. I have iPad Air 64GB but as I describe this title, touch screen doesn't work.
I mean cannot recognize any touching operation.
I open it but it doesn't have water damage, there are no connection problems. (because screen works well on the other iPad Air)
Strange thing is occasionally it works well for very short time then within 1 min back to initial condition.
How can I fix it? and where I have to change into new parts?
Score 5
Add a comment
1 Answer
Most Helpful Answer
So you took two iPad airs apart? When all the iPad probably needed was a restore
Was screen damaged or was it just the touch that wasn't going?
Score 1
2 Comments:
Hello. Thank you for your reply and your suggestions.
well as you mentioned, did all before open it. screen was beautiful condition and a little while it worked normally but suddenly, the screen became out of work. connections have no problem at all....
So, I open it and the screen is now working well on the other iPad Air.....
I wonder if it has program in logic board.....should I change into new board?
by
Sorry I misunderstood.
well, I have 2 iPad Airs and one (iPad A) had broken screen so, I removed broken parts from it.
iPad B has problem now. it was looks good but as i explain touch screen doesn't work.
now, I restore iPad A by using iPad B parts and it is restored perfectly.
I have parts to restore for iPad B already but I need to solve initial problem. Do you have any idea to fix it?
by
Add a comment
Add your answer
Jonathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 3,567
