Repair guides, support, and troubleshooting information for MacBook Air models with 11-inch displays.
930 Questions View all
Noisy Fan, Heating Issues, Slow Computer
My Macbook Air 2011, has a very noisy fan. It heats up abnormally on use, and when its really hot, it becomes very slow. I went to the Apple Store where they claimed that the entire machine is busted- they said liquid damage. I went to a repair shop and they said only the fan is busted and can be fixed with a 60 USD repair. Whom do I believe? Has anyone ever faced this issue?
Score -1
Add a comment
1 Answer
Chosen Solution
probably its just dirty fan.
remember to change cpu paste for better cooling.
follow this guide.
MacBook Air 11" Mid 2011 Heat Sink Replacement
good luck!
Score 1
1 Comment:
Do replace the thermal compound between the heat sink and the chips. I recommend Arctic Silver 5, it will lower the temps. Insofar as the fan goes: Remove it from the laptop. Put a drop or 2 of 3-N-1 oil on the brass bearing. Spin it around a few times by hand to work the oil in. Wipe any excess oil away with a paper towel. Put a small piece of paper over the bearing, then tape the paper to the housing. The fan should last you a few more years after this.
by
Add a comment
Add your answer
Maitreyi Gupta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 708
