Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
I can't find the fan.
I will replace the hdd in my emc 2210 with the Seagate hybrid. I want to replace the fan too because the error 4mot/1/40000003 hdd-1327 from the Apple Hardware Test makes it seem prudent to replace both BUT, after hours of searching I can't seem to find the exact hdd fan replacement anywhere. Is it possible that only a substitute for:Delta BFB0612HB APPLE P/N 620-4324 is available and I'm one of the few who doesn't know it? It is possible I'm adhering too closely to the model and p/n here? Can anyone steer toward the item I need? Thanks in advance. Kevin
Score 1
Add a comment
1 Answer
Chosen Solution
Kevinmoore75, the part number for your hard drive fan is 922-8510 and it is readily available at places like this and many others. hope this helps, good luck.
Score 1
2 Comments:
Greetings and thanks for answering. Am I to understand that I've been searching using the incorrect model number? I copied the model number and P/N from the photo on the ifixit instructions outlining the replacement procedure. While looking through various photos I noticed there are distinct differences in shape and wire/connection length (connectors?) on the various fans in the 2210 (cpu and optical drive fans) http://www.applemacparts.co.uk/store/fan..., I've just searched your suggestion and it appears you are indeed correct and I thank you. Question: what about the 620-4324 number? I'd assumed (perhaps foolishly) this number had to do with the wires or connector. Is that the case? Thanks for your help.
by
Not sure where that number came from. I went by the partslist for your computer model and that is where I got mine from. here is the compatibility for that part number:iMac 20" 2.0GHz Core 2 Duo (A1224) - Mid 2007, iMac 20" 2.0GHz Core Duo (A1174) - Early 2006, iMac 20" 2.16GHz Core 2 Duo (A1207) - Mid 2006,iMac 20" 2.33GHz Core 2 Duo (A1207) - Mid 2006,iMac 20" 2.4GHz Core 2 Duo (A1224) - Mid 2007, iMac 20" 2.4GHz Core 2 Duo (A1224) - Mid 2008, iMac 20" 2.66GHz Core 2 Duo (A1224) - Early 2009, iMac 20" 2.66GHz Core 2 Duo (A1224) - Mid 2008, iMac G5 20" 2.1GHz G5 (A1145) - Late 2005
by
Add a comment
Add your answer
kevinmoore75 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 155
