Boots to Android bot screen, and then screen just blinks
My Acer Iconia A110 suddenly quit working. It does turn on, but only to the Android splash/boot screen. I've tried hard rebooting it, but with no luck.
My Acer Iconia Tab7 does not switch off and the screen is faint and blinking.Ive tried rebooting but there is no progress.
(Search how to soft or hard reset your unit. MAKE SURE your battery is fully charged before re- setting. If cant re- set, try whats done below..)
I bought my Acer A1-810 it’s 2,5 months (from amazon). And few days ago I decided to root it. 1 hour later i realized that was not a really good idea, because i did not know much things about, and it was not as easy as I thought. and voila as a result : bootloop !
I tried different roms, different update.zips but got allways the same error : ” check.partition.size=[__PROP_UNDEFINED__] ”
I was desperate…I was at the point of resend it to Acer for repair. But last try was successful, I did it, I did !!! And there is how !
1. go to acer web page --->support--->drivers and manuels
2. choose your model acer a1-810
3. As my divece was bought in usa, my FW upgrade is AV052.RV26RC06.PA.CUS1 (in O.S ), download it !
4.when it’s done, you should unzip and should get update.zip separately.
5. Put update.zip on SD card
6.Put SD card in your device.
Push power button then options will appear. Choose external source for the sd
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 225
