Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Questions View all
Question Closed
Replaced power/volume cable and now the LCD won't start up?
During a routine Digi replacement my coworker cut the power/volume cable. After replacing the cable and the Digi the iPad begins the start up process and then goes black. After that I get nothing. I have replaced the power/volume cable again, diconnected the battery, tried an alternate LCD etc and nothing works. I cannot get it to sync with iTunes to do a DFU reset because it requires you to acknowledge it on the iPad which I obviously cannot do. It is not a back light issue because there is nothing to be seen under direct light. When I plug it in to a power source I can hear the sound so I know that there is power but I get nothing but a black LCD. I am at a loss.
Add a comment
1 Answer
Take a look at the power/volume flex cable where the smart cover sensor is, it should look like the original flex, it not then transfer the old components to the new flex. You will need a soldering iron to preform this operation.
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 101
