Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
Shuts off on startup!
This is my daughter's computer. I'm visiting this week and would love to solve the problem while I"m here. What happens is that when you power up the computer, it bongs, the screen turns white and then it shuts down.
If you hold the power button down for about 15 seconds, it starts normally. If you do a restart once it powers up, all is fine. If you shut it down and press/release the power button to start it, there is a bong, the screen lights up for a second, and then it dies.
So far, I've repaired permissons, reset the SMU and NVPRAM, run disk utilities, and fsck.
The computer is orignial, with all system (10.6.8) updates applied. I did find some nasty adware once I got it going, which I think I removed. The battery has been replaced, but other than that, everything is OEM. I did notice that the rubber feet are missing from the bottom of the case.
Ideas?????
Add a comment
1 Answer
Kinda hard to answer but first thing witch comes to mind is either ram or mobo.
You should try memtest for the ram
If all is fine with the ram I suggest taking a look at the capacitors on the motherboard to check for any leakages or inflated capacitors.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 159
