Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
I accidentally fed my iPhone's 4 headphone jack with 9V DC
I accidentally fed my iPhone's 4 headphone output with 9V DC while playing around with electronics. **I'm an idiot, I know that**.
The phone then rebooted and now all I get from it's output is a distorted crackling sound.
I've thought of replacing the headphone jack, however I found out that using a line out cable from the dock gives the same distorted output, so it probably wont fix it.
Is there something I can do to try to fix it besides replacing the entire logic board?
Add a comment
1 Answer
Most Helpful Answer
Joe Lenn, use the repair guides from here. That is the first thing I would replace. While you are working on that, check the logic board for obvious damage, like a burned, charred component. Should this not work, you may have take a closer look at the audio IC. This would be a difficult repair and should be done only if you have the experience and the tools to do a reball. Hope this helps, good luck
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 102
