Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
iPhone 5c won't turn on
I have a iPhone 5c which has the sleep button not working because for some reason the circuit was torn off from the lock button (everything else worked perfectly). So I bought a circuit in attempt to fix it. Half way through I decided that I'm not gonna fix it because I could not get the battery off the phone and I got fed up of all the small parts so I assemled everything back together.
However the problem is now I put the phone on charge, press and hold home button but the phone won't turn on. It would only vibrate every couple of mintues (when on silent) or make that beeping sound every couple of minutes (like it was waterdamaged?). What could be the problem?
Could it be a problem cause when reconnecting the screen?
Before anyone suggests, I can't take the phone for warranty because 1. it is now broken and 2. device was bought from another country so it did not apply to my country!
Score 1
Add a comment
1 Answer
Most Helpful Answer
You have damaged the screen that bonging indicates it's damaged you will need another display
Score 1
3 Comments:
Thanks for the reply. So another screen will solve the problem?
guess I'll have to be extra careful when changing the screen
by
@con is it possible that the battrey needs replacement not the screen since I might have bent it in attempt to remove it?
by
Not really the bonging Is a indication that the screens damaged seen it more than enough times..
by
Add a comment
Add your answer
Eric will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 741
