Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 Questions View all
ps1 Wont read memory card, and not vibrate
I have a psone slim model 101, that wont read mcs and the joystick wont vibrate, i tested others mcs and joystick and nothing, this problem sstarted when I open the console and the button that turn on the laser I used a screwdriver to press the button and the tip fall on the fuse and make a small sparkle, sorry for my english but i think u can understand, i hope u people answer my question
2 Comments
ls92, it could help if you can explain this "I used a screwdriver to press the button and the tip fall on the fuse and make a small sparkle" a bit more. Or you can post some images of the area with your question. This way we could try to determine if you shorted out some component. Use this guide Adding images to an existing question to help you with that.
by
I had problems with my PS1 memory cards not reading on my PS1 but ik they're good cause I tried them on my PS2 but I didn't have the screw driver accident I have no clue why they don't work
by
Add a comment
1 Answer
Chosen Solution
well i cant tell for sure if this happens on ps1, but on ps2 the memory card and controlers share the sabe ribbon cable. check if its loose. if its not, take it out and put it back in anyway, do a little blowing on the sockets in the mean time. after that, fire the badboy up and see if it works ;)
Add a comment
Add your answer
ls92 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 22
All Time: 3,070
