The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
594 Questions View all
The touch in my screen has stopped working, what can I do?
My Samsung Galaxy S3 endured slight water damage, not a significant amount, and worked fine afterwards.
A few hours later, something happened to the screen and now the touch in the phone will not work.
It turns on and off and charges as normal but i cannot use the screen at all.
What can i do to repair it myself?
Add a comment
1 Answer
First off remove the battery from the phone otherwise it will shorten and will continue to be burned components!
There is no doubt that corrosion caused the malfunction on the touch screen, If I were you I would open the device from the areas in which there is corrosion and simple to clean with a toothbrush and alcohol to clean the contact.
Note that the screen has components I'm sure there'll corrosion in this area, but do not overlook the motherboard.
It is important not to use too much alcohol on the screen, only a small amount and clean.
If it did not have to try to replace the screen, even if it did not have a problem on the motherboard ...
From my experience if you clear well everything will work! :)
  • IMPORTANT! Remove the battery and did not charge it until after cleaned and properly continent!
Comments:
So i'd clean the motherboard in particular? As well as everywhere else?
by
Unfortunately, the method of cleaning has not worked on my phone. The touch in the screen remains broken. Thank you anyway.
by
Add a comment
Add your answer
Chloe Shippey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 243
