2.3L 4cyl or 3.0L V6, 6th Generation
427 Questions View all
My tachometer isn't reading correctly on my 1999 Honda Accord V6.
When I take off fast it goes all the way past 8500 RPM'S . if the motor was really turning like that it would throw a piston through the hood. Can somebody please tell me what to do....
Score -1
2 Comments:
What is your RPM's when idle? and does the engine keep reving when idle?
by
It idles at between 1000 and 1100 RPMS. No it don't surge. I think its just not calibrated right. It had a 2.3 and was upgraded to the 3.0..
by
Add a comment
1 Answer
From what I'm reading, the most common fault that causes this is a faulty ignition coil, like the internal resistor is shot. Though it could also be a fault in the electrical wiring its self, a sensor problem or the tachometer cluster. Have you checked those out? Also, you wouldn't happen to have a Vehicle Diagnostic Code Reader? You might be able to find the fault code of whats causing this.
2 Comments:
Ran em and it says O2 sensor
by
Thanks for the information.
by
Add a comment
Add your answer
Joey Evans will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 527
