Repair guides for many brands of PC laptop (notebook) computer.
9639 Questions View all
How to remove stuck SD card out of laptop's card reader?
Hi everyone!
A while ago I inserted the dummy card in my laptop's card reader slot, but it got stuck. Any ideas how to get it out the slot, so I am able to use the slot?
Thanks!
Andrew
Update
I have tried it several times, but I am not able to get the needle to the end, because there is not enough space. Even with a second pin I am not able to get it out of the cardreader. On the other side are the contact pins and my needle gets stuck there.
Should I use a hobbytool to drill the dummy to pieces? I am affraid that's the best option...
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Get a fine sewing pin and put a little hook on the end (about 2mm hook) get the hook in behind the card and gently tug. You may have to use a second pin without hook to guide the card up or down.
Score 2
Comments:
I used sewing needle to pry it out--picking at it from the front on the sides and bottom. (It's made of soft plastic and I don't mind if I damage it.) Eventually it came out. YEA!
by
Thank you! Thank you! Thank you! Thank you!
by
I uses a very thin sharp knife slid it in the top of the card. Then I wiggled it from side to side. The right side then came out a little more eventuall wiggling it side to side and the left side released. I put it back in and had same problem so I threw the card out and new one worked fine. I believe it was catching on sides not top or bottom.
by
Add a comment
take some tweezers and pull it out of the card reader thats how I got mine out
Score 1
Comments:
It didn't work!
by
Just damaged the SD card
by
Add a comment
A thin pointed knife and 1 chopstick on each side - ejected in less than 30 seconds.
Add a comment
Get some pliers and pull it out.
Add a comment
I got a small piece of packing tape (other tape would probably also work) and inserted it next to my SD card. I kind of pressed it a bit against the SD card and was able to pull it out.
Add a comment
Add your answer
Z3pcs will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 181
Past 30 Days: 674
All Time: 24,606
