Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
iPhone 4, NO wifi & Bluetooth signal, NOT grayed out. Any solution?
I have a iPhone 4 GSM 8GB iOS 7.1.2. I had previously faced the "gray out" issue of WiFi/Bluetooth and I have gotten it fixed. Both WiFi and Bluetooth can be turned on/off now. WiFi's MAC address is displayed inside "Settings". 3G signal is functional.
(I have it fixed by removing and installing the same WiFi antenna several times...)
However, NO WiFi signal can be detected after I have fixed the "gray out", even if I put my iPhone near my router. Although bluetooth signal CAN be detected, it cannot connect or pair with any other devices. And it seems that the 3G signal has been weakened after I have fixed the "Gray out' issue.
AppleCare has expired.
I have been searching for solutions but none is yet helpful.
Any help or suggestions are very appreciated :D
Add a comment
Try resetting all network settings
Add a comment
Did you find a solution for this?
Add a comment
I had no wi fi since i updated to 7.1.2
Sem Wi fi desde a ultima actualização para 7.1.2
após todas as tentativas falhadas de troca de antena, uso de secador, reposição das definições de rede, restauro...enfim uma longa lista de tentativas falhadas descobri como resolver de uma maneira muito simples o problema que muitos usuários tem vindo a encontrar com o iphone 4.
solução:
1 repor as definições de rede (mesmo que fique cinzento sem que possa ligar- desligar)
definições-repor-repor as definições de rede
2 alterar o nome do iPhone para um nome diferente de preferência curto
definições- informações-nome
3 desligue o iPhone e volte a ligar normalmente.
é possível que tenha de repetir o processo, se esse for o caso altere sempre o nome do iPhone.
4 pode fazer um donativo para a conta abaixo ajudando a manter a pesquisa de novos problemas.
Nib 004531164020708018855
iban PT50 004531164020708018855
obrigado
Add a comment
Não consigo emparelhar um Handsfree Car Kit com o meu Iphone 4 8G...deveria aparecer no iphone um item para selecionar o emparelhamento, isso não está a acontecer. Podem ajudar-me. Obrigado.
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,857
