Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Battery life extremely limited; even after battery replacement?
Greetings,
After replacing the lock button on my phone; My battery life has been very short. In example : full charge at 0900 hrs has to recharged before noon. Thought the battery was old and replaced it, helped but is no where near the expected.
Score 1
Add a comment
1 Answer
It sounds like there is a logic board issue. As the phones get older of course battery life decreases, lithium ions have a two year life however if that is not fixing the problem I would wager to guess that you are having issues with you logic board and there is no way I know of to repair that other than Cyberdoc LLC and I am not sure if they can fix that without you being able to identify which transisitor controls the power drain.
Other than that I would try the usual tricks: turn bluetooth off, close out of apps and turn your brightness down.
Hope this helps!
Add a comment
Add your answer
revanantwraith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 74
