Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
282 Questions View all
MB985LL/A - MacBookPro5,3 - A1286 - 2325*
Hello, As per your guide I don't see the BT board near the hinge and DVD drive on my Macbook Pro 15" Mid 2009.
Also there is no guide on WiFi module replacement. I am having problems with WiFi connectivity and want to replace the WiFi module.
Question: In my case, is the WiFi and BT module a single unit inside the clutch cover? Also, is it possible to remove the clutch cover without removing the screen glass? What is the WiFi module part number for my laptop top? Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
There is two different Bluetooth setups depending if you have gloss or anti-glare screen. Only the anti-glare model has the Bluetooth board mounted near the optical drive.
You are correct this model has the AirPort board sandwiched in the clutch cover.
Follow this guide MacBook Pro 15" Unibody Mid 2009 LCD Replacement which you can see is the same procedure as the older model direct instruction on how to get to the clutch cover and the AirPort board: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement
But before you go down this path make sure you have double checked your connections and see if you have any damage on the lid which could effect the antennas.
Score 2
Add a comment
Add your answer
Bobby Patel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,112
