Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Questions View all
3DS does a poping sound and doesn't turn on.
So, I know this problem is usually related to defective ribon cables, but there are quite a lot of ribbon cables in there and I'm not sure about which one is defective.
My 3DS also wont show image when it is only opened a bit.
I tried removing and reinserting all the ribon cables and it didn't make diference, so I'm guessing the problem is not with the conectors. I also checked continuity in the fuses and they're all good.
After testing a bit it seems that the pop sound comes from the speakers, since there will be no sound when they're disconected from the mobo, but it still wont turn on the screends. I also tried disconecting the camera and the top screen and the console would still show no image and it would turn off little after being turned on.
Add a comment
1 Answer
Chosen Solution
Here are the steps I take when diagnosing this problem:
Step 1) Make sure the battery is fully charged...this just ensures that the diagnosis is accurate.
Step 2) Take the console to a very dark room. Push the power button then put your finger over the blue light. Watch the screens to see if either of them flash.
Step 3) If the top screen flashes then you most likely have a problem with the lower screen ribbon cable. If the bottom screen flashes then you probably have a problem with the upper screen ribbon cable. If no screens flash then you most likely have a problem with the speaker ribbon cable.
Step 4) After diagnosis check the ribbon cable.
Most of the time you will find the problem to be the speaker ribbon cable. A lot of times this ribbon cable gets a small tear right where it goes through the hinge. Sometimes you will find corrosion (or just find them loose) on the two ribbon cables that come out from the top screen.
Also, if this console has been repaired before sometimes you will find that when the previous repairer installed the ribbon cables onto the motherboard then damaged them near where they connect to the board.
BTW, this problem is not caused by fuses. The fuses on the 3DS hardly ever burn out.
I hope this helps.
Score 1
2 Comments:
Long time to reply, but I am having the same issue you describe. I bought a 3ds for 20 bucks and the power will shine blue for five seconds and make a pop sound. The bottom LCD backlight glows but the top doesn't. I will try to replace the LCD r
by
This problem started after I opened my New Nintendo 3DS XL to make sure there was no water damage because I had accidentally left it in the rain. I completely forgot it was outside. I didn't notice anything, and it was surprisingly dry, so I put it back together to try powering it on.
I just tried your diagnosis, but nether screens flash and all cables look fine. One time, while taking it apart, I lifted the white thing that secures the cable in place too hard and it popped off, however, it doesn't seem to have effected connectivity to the battery and shouldn't have anything to do with this issue seeing as it was going on before I broke it.
there was also a grey and black ribbon cable I tried pulling out but wouldn't come, though I looked at it but it didn't appear to have been busted in any way. I later realized you lift the plastic piece on the opposite side of the cable.
by
Add a comment
Add your answer
Mateus Battalini will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 38
All Time: 840
