Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1501 Questions View all
home button doesn't work
I changed my back cover on my iPhone 3G now the home button on the front doesn't work? can u help? cheers
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Most Helpful Answer
go back in and make sure that the home button contacts are connecting with the logic board
Score 1
Add a comment
1) Check the contacts.
2) Check that it is synch'ing to computer, if not then need new dock connector unit.
3) Also check cable 4.
Score 1
Add a comment
Hi, i have the same problem when i plug it he charge to be on then she don't charge ! the home button don't work but the micro and other it work ! i don't understand ! itunes don't synch ... plzz help
Add a comment
Hi, how did you solve the problem? I have the same issue. After replacing the back cover, my home button does not work. Sometimes it gets stuck but even when it doesn't, it does not work. Any advice?
Thanks!
Score -1
Comments:
This should be its own question.
by
Add a comment
Add your answer
TOM WOODS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,407
