Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
only charges when screen is off, doesn't connect to pc
When my phone is plugged in to the pc, it will charge if the screen is off. As soon as i click the home button, it stops charging and doesn't show on the screen as plugged in. It also won't recognize it on the pc or Itunes. I already changed the dock connector with a known good one and doubled checked it to make sure.
Any suggestions?
Score -1
Add a comment
1 Answer
Hello Mat,
So I had this very same issue with my iPhone 4(CDMA) and I changed out the battery, dock connector and even tried a water damage treatment once I got desperate. However this issue is seeded deep then the simple hardware and is an issue with the motherboard. There is no known fix (that I could find at least). However I would try DFU mode and see if your computer recognizes it.
DFU MODE: http://osxdaily.com/2010/06/24/iphone-df...
Add a comment
Add your answer
Mat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 135
