The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Questions View all
After changing the LCD, Phone is not working
Please help me.
I just fix my LCD screen from some store, and they fix it by 240$. Then, I tried to turn it one but there is no response from the phone. It doesn't work at all when I connect the battery, but after I connect the Charger (Power Supply) It gives the sign for charging and battery level. But when I try to turn it on, it is not working.
Before I fix the phone, everything is working good. Please Help
1 Comment
please help!!!!!!!
by
Add a comment
Chosen Solution
http://m.youtube.com/watch?v=Gre9qaJyCZw
Try this
Add a comment
You need to let if charge up for 10 minutes or so before it will turn on
10 Comments:
I changed the phone LCD, from the phone fix store. But, they said that I need to do some software set up, and they did not know how to do it.
The problem with phone after they replace the LCD that when I turn on power, I'm getting no response. not turn on, just black screen without any thing. My Question when I plug in the charger, it gives me the sign for charging and then disappear. and return to BLACK screen for long of time, PLEASE HELP!!
by
Bring the phone straight back to the shop that was supposed to repair it and demand they get it turned on .. Was the phone working when u left it in?
by
Yes, it was working FINE, but after they changed the LCD, it is not working.
Do u Know What is the PROBLEM ?
by
The PHONE is Not Working, Can U explain for me WHY????
by
Well the lcd seems to be working as the battery logo coming on screen sounds like the power button is broken..
by
Show 5 more comments
Add a comment
Hi,
I just fixed note 2 screen. Every thing was fine before closed every thing I put battery to make sure every thing was fine. After that I put back panel or cover(over mother board) of the set and closed every thing then I put battery but phone is not getting turn on.when I remove the back cover it works perfectly... I am just wondering what happen every thing is fine with out back mother board panel.
Thanks
Umar
Add a comment
After replaced my LCD samsung my phone is doesn't work my screen shot? What happened do I need to turn back to the repair shop?thanks I hope u reply
Add a comment
Add your answer
Joseph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 29
All Time: 454
