Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Slides/gestures after change of battery (3 GS)
Everything else wifi (jailbreak springboard on top left), music (home button voice command) seems to work. Most of the areas are unresponsive. After reboot I also can´t type all numbers.
Could be a loose connector? If yes which of them?
The iPhone is running now with WiFi, Music, Location, Buetooth to empty the battery. Then I gonna open it again.
Can I also open it while running? Will it turn off automatically or is dangerous? I just ask cause I can´t use the slide to switch function. Any other solution?
Many thanks.
Score -1
3 Comments
Okay it was the connector. But now I can´t charge it. As soon as it´s unplugged it switches off. Any idea?
by
I tried two different chargers - doesn´t work.
by
Did you check the battery ?
by
Add a comment
1 Answer
Chosen Solution
After mounting the original battery it seems to work.
So I guess the new battery is dead.
The label of the new one says 3G but I got 3GS.
Does this make any difference?
Add a comment
Add your answer
Quazzimodo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 968
