iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
Replacing the graphics card might cause heat issues?
I was reading a guid on changing the graphics card on an 2009 iMac EMC 2374 has an ATI Radeon HD 4850 512 MB with a Radeon 6970 2GB graphics card.
It sounds great but in the discussion it is mentioned that there is a heat eminence issue that needs to be fixed by thermal compound and fan speed adjustment. However this is not an issue the author brings up but another member that did the switch on a different machine (iMac a 2010 i5 2.8)
Does anyone know if this will also affect the 2009 iMac EMC 2374 that has an ATI Radeon HD 4850 512 MB?
Score -1
Add a comment
1 Answer
Chosen Solution
Hi,
I have put a Radeon 6970 2GB into my 2009 iMac EMC 2374 and have had no issues, the graphics card runs at the correct temperature and the fans run normally.
I hope this helps.
Score 2
1 Comment:
Thank You!
This is good to hear
by
Add a comment
Add your answer
Gato will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 221
