no power all of a sudden, after replaced caps
My iMac had a checkerboard screen, AHT reported an error with the video ram. I replaced all the caps which changed nothing. I pulled the LB out and pulled the heat sink off the video chip, cleaned up all the excess thermal compound and started it up - everything was working perfectly, so I went to grab a cup of coffee (2-3Min), when I returned, there was no power. I didn't have the LB screwed in, it was just propped up in the case, also only had the video, inverter and power supply plugged into the LB. No fans, sound... There was no smell or movement of the parts and neither the video or the processor were hot.
The power supply is OK (12,5,3.3V) leaving the dc/dc - without the LB plugged in the HD will spin and I get the proper volts at the connector. But when I plug it into the LB and power on the #1 LED blinks and the power supply shuts down... I have reset the PMU. I suspect the caps, I checked all them a hundred times but I can't get an accurate reading on the caps because they are in series. I would hate to have to replace them again
Does anyone know why the trickle voltage would make it shut off? Any ideas where I should look first? Troubleshooting ideas?
Score 1
1 Comment
OK, I narrowed it down to the two 12v constant voltage pins on the 12 pin power cable. I pulled the pins from the power cable and then I get #1 LED green. #2 won't light up and the run voltage is very low??- I thought the two 12v went straight to the inverters, but I must be wrong... anyone have any ideas on this?
by
Add a comment
Chosen Solution
Oh yeah, I've checked and re-checked. I got another board and everything is working OK now. It just annoys me that I had it fixed and then it died on me...
Score 1
Add a comment
Most Helpful Answer
Have you checked the polarity of your replacement caps? I know i have on an occasion or two switched my negative and positive in a rush to replace them.
Score 1
Add a comment
Add your answer
Vince will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 25
All Time: 2,226
