iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Question Closed
Music doesn't play out my left speaker/earphone unless I squeeze it
Basically, when I play a song on my iPod Classic, the music only plays out of my right earphone unless I squeeze the iPod and then the music will also play out the left earphone.
I regularly have to squeeze it because the left headphone will stop working after x amount of time.
The earphones work fine. I have tried plugging the ipod into my car stereo and the same thing happens ( Using the charger cable not AUX) I still have to squeeze it so that the music plays out of the left speakers.
Add a comment
1 Answer
Most Helpful Answer
Hi Matt,
It sounds like the mini-jack connector in the iPod isn't working properly. It could be that the connector in the iPod that connects the mini-jack cable to the motherboard is loose. But it is also possible that the mini-jack itself is just broken and needs to be replaced.
You can replace it using this guide:
iPod Classic Headphone Jack & Hold Switch Replacement
And depending on the model you have you can buy on of these replacement parts:
iPod Classic (Thin) Headphone Jack & Hold Switch
iPod Classic (Thick) Headphone Jack & Hold Switch
Good luck!
Nathan
iPod Classic (Thin) Headphone Jack & Hold Switch Image
Product
$9.99
iPod Classic (Thick) Headphone Jack & Hold Switch Image
Product
$29.99
Score 1
1 Comment:
Thank-you so much!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 966
